Roshan1286
Mar 12, 2023Follower
Apple Homepod & Nighthawk MS60 Mesh System Connectivity
I wish Netgear would fix this issue with AirPlay and AirPrint without having to disable Private/Random Wifi Address. I am using all these devices with the latest updates and I have to either reboot t...
Mar 13, 2023Guru - Experienced User
It was something Apple rolled out that broke how their devices connect. I'd look to them for a fix because the issues aren't just on netgear routers. If you search other forums, its not an isolated thing. Its because of how apple rolled out a "More secure" feature that causes the issue.
