JPRBDE
Nov 11, 2023Aspirant
Are MR63 satellites compatible with MR60 system
I have a MR60 system with 2 satellites. Could I add one or even two MS63 satellites to this system? Would it even help to get a stronger signal where the new satellites are?
michaelkenward
Nov 11, 2023Guru - Experienced User
When looking for satellites, careful to find one that works with the MR60.
The MS60 is a safe best.
Unfortunately, Netgear does not seem to have come up with a grid that covers all MR and MS devices.
JPRBDE
So if I understand the info in the provided link, a MR63 satellite will not work with a MR60 router. If I want to add satellites beyond the two I have now, I will need to use MS60 satellites. Do I have this right? Sorry, I'm really not very knowledgeable about this stuff.
- michaelkenwardNov 11, 2023Guru - Experienced User
I have no idea how you arrived at that conclusion. That link is all about the satellites that will work with the MR60 router. It says nothing about the MR60 router. (That's why I complained that Netgear doesn't provide a complete grid of all MRs and MSs.)
There is no MR63 satellite.
Look at the labels on your MK63 system and you will see that you have an MR60 router and two MS60s satellites. (The MK62 has one MR60 and one MR60.)
You can just add two more MS60 satellites to the existing MK63 system. The trouble could be in finding standalone satellites. They can he hard to track down in some markets.
michaelkenward wrote:Look at the labels on your MK63 system and you will see that you have an MR60 router and two MS60s satellites. (The MK62 has one MR60 and one MR60.)
(The MK62 has one MR60 and one MS60.)
- JPRBDENov 13, 2023AspirantThanks.
Like I said, this is not my area of expertise, so I appreciate all the help I can get.
