Keisler
Feb 20, 2024Aspirant
ATT BGW320 and MR70+2xMS70 daily dropouts
Please help me resolve a problem with daily dropouts that impact my wifi that works from home. Here is the setup: ATT BGW320, 1GB fiber installed on first floor in MBR. Tests reliably at 1320 down an...
- Feb 20, 2024
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Keisler
Thanks very much for your thorough, very helpful, and super fast reply. I will try #2 and report back.
In reply to your qs:
What is the size of your home? Sq Ft? 2400, 2 level
Modem to MR is 2 ft, connected with Ethernet cat 5 cable.
MS70 #1 is about 30ft from MR70, and on first floor close to the stairwell up.
MS70 #2 is about another 30ft from MS#1 and further from MR70.
If you were purchasing new equipment today what would you recommend?
Many thanks!!
Many thanks!!
Keisler
I wanted to add that my wife works for the federal government (VA hospital) and she likely has a VPN for her laptop setup.
I think the help articles referenced mention a VPN can pose a problem for solution path #1. But I will start with solution #2 first, as directed. Thanks again!
- FURRYe38Feb 20, 2024Guru - Experienced User
Ya having double NAT condition would and could effect VPN configurations. Hopefully option #2 helps with that.
