HankG60
Apr 10, 2024Aspirant
Automated Scheduling reboot of MR80
I have an MR80 router that had 2 MS80 satellites, one died and I got a replacement , the system seems to lose internet connectivity on the wifi side (ethernet is consistent. but I need to reboot the ...
Apr 10, 2024Guru - Experienced User
Yes one could use a timer.
However this would be avoid the real issue. Why is the wifi failing? Can you give more details about this?
MK systems should not need any power cyclilng or reboots to fix something, if it's needed, then there is a problem that needs to be vetted.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many MS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between MR 📡 and MS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡 ‌‌🛰️
Does this happen with the MS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
