ZtuNZeeD
Dec 10, 2023Follower
AX1800/AX1500 Compatibility and AP/Extender Modes
We purchased a Nighthawk AX1800 (MK62)(MR60) router with 1 (MS60) satellite extender back in August 2020 and just this year we installed a surveillance system that required a direct connection to a r...
michaelkenward
Dec 10, 2023Guru - Experienced User
ZtuNZeeD wrote:
I also wanted to ask about how I would go about using the extra (MR60) router as an Access Point or an Extender.
Access Point might work, but not extender or repeater mode.
- Advanced Setup
- Wireless AP
MK Mesh routers don't have a wifi repeater (bridge) mode.
The MS60s should just connect to the existing MR60, although you may have to get them on the same firmware for the connection.
I've been shopping around for extra satellites and I finally found a decent deal on a Nighthawk AX1500 (MK6W-100NAS)(MR60) with 2 (MS60) satellite extenders, thinking they would be compatible
Is MK6W a typo? The two satellite model should be MK63.
