DJ_UNCLE_MATT
Aug 24, 2024Aspirant
AX3600 MK83 - CAN I CHANGE THE SSID ON SATELLITE?
Hello. This is my first post, first nighthawk, first mesh system. My wife bought me an ax3600 mk83 mess system on Ebay used. got the manuals online and while looking at the SSID'S, I noticed that ...
- Aug 25, 2024
Thank you for your assistance.
Once you figured out from my incoherent ramblings, what I actually needed, you sent me this link: MR80 / MS80 Firmware Version 1.1.7.14 - NETGEAR Support
This was a site not visible to me at the online support. It was easier then.
The Zip files were the same: MR80-V1.1.7.14_3.1.109.zip and MS80-V1.1.7.14_3.1.109.zip I had but there was more information at: https://www.netgear.com/support/product/MK83.aspx#docs, where I could select the topic Troubleshooting and find at the top of page 2: the article labeled NETGEAR Connected Home Products FAQ. Now once in here I then found WiFi Routers and in the pull down menu found: How do I update the firmware on my NETGEAR router with a web browser?. This is where things began to click, and I could swear a new upload button appeared at the bottom! I know it didn’t, but I sure missed it 12 or 20 times.
Everything is up and working wonderfully including a guest account, wired units and wireless. We have optimum 500 Mbps / 20Mbps and Ookla is testing at 506 to 517 down and 20 plus up. I am verry happy. Thank you.
Now, were do I go to rate you 5 stars?
DJ_UNCLE_MATT
Aug 25, 2024Aspirant
Yes, I tried but still does not recognize the ms with a different ssid. I can see it as a seperate wifi on devices in the house but not in the routers software.
michaelkenward
Aug 25, 2024Guru - Experienced User
How about sorting this out first:
firmware update on ax3600 mk83 mesh - NETGEAR Communities
Just another user with time on their hands.
- DJ_UNCLE_MATTAug 25, 2024Aspirant
Yes that was my post also. Firmqare wont update to 14. Says it is inncorrect for ms80 as i tried as instructed to upload that first.
- michaelkenwardAug 25, 2024Guru - Experienced User
I know. That's why I suggested fixing the firmware.
Are you sure you have the right firmware ans the right modem number?
As this is a second-hand eBay purchase, I'd be careful to look at those details. You never know what the seller put in the box.
Did the firmware work on the other MS80?
No it could not see the ms80 mwith a different ssid. so, i unplugged the errent ssid and tried to updat what was working. ms80 first as instructed.
Is there different versions for mk83 tri. when i go to support, i type in nighthawk ax3600 mk83. it takes me to that download area and i got the mr80 and ms80 zips. i unzipped and ried to use the manual upload featut in my router. i have read the instructions ans follwoed the prompts in the router which math the written steps.
you said i dont need internet to update. i use my google acct and go in with the 10.0.0.1 admin and pass. iI the router does not see the errent ms80, can connect the mr directly to errent ms in hopes it would sync or try to upload to it.
