xtramm
Nov 24, 2020Initiate
backup.cfg zip password
MY MODEL IS NIGHTHAWK MK42 (MR60 on admin page), firmware V1.0.6.102_2.0.45
i want to access to my backup cfg file. i notice that is a zip holding another backup.cfg file. the zip request a password.
so, where can i find this password?
thank you
MK62 is a kit with one MR60 router and two MS60 satellites. Unfortunately these aren't added to the community tags....
You have access to the file - perfectly sufficient as a backup and to reconfigure from scratch. Access to bits and bytes isn't required and not intended.
- xtrammInitiate
Thank you so much for tell me that access to th file backup is the only thing i need. i don't realize it by myself!
anyone have decripted this file? the file download with cfg extenion but is a zip file.
this fantastic router have lost the port forwarding table in some deep dark place ancd wont to recreate the configuration. only this that can i do is restore factory default and rebuild entire configuration. no backup restore solve the problem beacuse the problem backup itself.
.. and no telnet interface!
next time, simply accessing to file backup i could will solve the problem editing the configuration backupped.
so, what is the password of zip backup file masked as cfg file?
thank you
