c_of_c
Jan 19, 2024Star
Best Nighthawk Mesh System to upgrade to from R7960p?
Hello, I currently have Netgear Nighthawk R7960p router (Nighthawk X6S) model.I am looking to upgrade to a mesh system, as my home has 3 levels and a mesh system will provide better coverage. Whi...
- Jan 19, 2024
Is the lowest level a basement area or just a main level?
Basements are not recommended places for the main host router. Concrete and steel will inhibit good signal travel.
If your looking for Nighthawk MESH, then I'd probably go with the MK83 series. 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡 ‌‌🛰Or an Orbi 752 or 753 series. Though for that size of home I believe you could get by with a router and just one RBS for the Orbi system. ️
c_of_c
Jan 19, 2024Star
Home is 3200 sq ft on 3 levels. Have about 50 WiFi devices supporting smartphones,laptops, tablets, security cameras, thermostat, streaming devices All 2.4 or 5ghz. R7960p is on lowest level (that is where cable enters the house) and signal reaches all areas but not as powerful on top level or outside. Also have wired devices but mainly on the first level, a couple on the second level via powerline. Future devices, it just depends, I hack around but rarely do anything "leading edge".
Jan 19, 2024Guru - Experienced User
