truss
Apr 28, 2020Tutor
Best Nighthawk r7000 upgrade for working from home
Hello, Hoping for some recommendations for upgrades. I currently have a Nighthawk Router R7000 located centrally in my house. Wifi hasn't been an issue really until my wife and I started work...
truss
May 04, 2020Tutor
- Firmware Version V1.0.9.88_10.2.88
- R7000 not sure why r7000p is listed
- Hitron CGNM-2250
- 300Mbps
- 90Mbps down, 14Mbps Up on 5ghz. Wired is no problems
I can't correlate with video messages. I got to the point where I just go and plug in, when I need to make a call. We both have similar issues, and are with different companies. Both use CISCO though...?
May 04, 2020Guru - Experienced User
truss wrote:
- Firmware Version V1.0.9.88_10.2.88-----Not the most stable firmware for the R7000. the agreed upon stable firmware is 1.0.9.42. You can try downgrading to this, factory resetting, and re-installing.
- Hitron CGNM-2250-----Which is a modem/router combo device. And if its not in modem only/passthrough mode or the netgear in AP (access point) mode, it can cause issues as you're in a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
- 300Mbps
so a couple issues you could work on.
1. get the r7000 on a stable firmware.
2. make sure you're not running a double nat.
3. try other wireless devices once that's fixed. What are you testing 5ghz on? have you tried different sites/devices?
- trussMay 05, 2020Tutor
Thanks for the info.
Definitely doing the double NAT...
That said, I moved one laptop to the ISP router 5GHz, I am on the Netgear 5GHz and all other devices are ont the Netgear 2Ghz. No issues to date.
I will play around with the single NAT soon.
Thanks again.
