Ian57
Jan 04, 2022Follower
Blinking white light for MS60
Had 2 full M60 systems. Both routers setup, 1 as an AP. 3 of the 4 sats setup around the house. Yesterday I had to reboot main router and even factory rest it. Today it all crashed, nothing worked. I...
Jan 05, 2022Guru - Experienced User
So lets try setting up just 1 MK system while leaving the 2nd OFF.
Try to Sync the MS near or in same room as the MR.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
je13air47
Feb 14, 2022Aspirant
This KB worked for me, it was a little annoying, but the tech I had was patient. After we tried all the standards, this was finally the one that got it going.
- dmsaeFeb 20, 2022Aspirant
je13air47's method fixed my problem. I had blinking white lights on all satellites after attempting a FW update through the Nighthawk mobile app. I tried power cycling and hard resets, but none of that fixed the problem. I'm not hardware savvy, so I was reluctant to push a FW update through a hardwired connection, but I followed the instructions exactly, and now my my mesh network is working again.
- FURRYe38Feb 21, 2022Guru - Experienced User
It's recommended to use the MR or MS web pages first to push any FW updates to the MS first, then MR lastly using a wired PC. Wireless is not recommended.
TFTP would only be needed as a last resort.
Using the mobile NH app can be problematic and is not recommended to do any FW updates thru.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- StbricehJul 07, 2022AspirantDoing this process fixed your satellites stuck on blinking white problem? Because I have one satellite that's been doing this for months. I gave up on it, I've tried factory reset, pressing the sync and the reset together, it never responds.
- dmsaeJul 07, 2022AspirantYeah, I followed the instructions, and it ended up being easier than I thought
- clowdurAug 28, 2022Aspirant
From Youtube comments section (https://www.youtube.com/watch?v=XeoS0xVINOE😞
"If anyone still fails with these instructions from my experience try this next one: use 30-30-30 method (push reset button 30 seconds and remove power cable without removing your tool whatever from the reset button - wait 30 seconds and put powercable back and also continue pushing that reset button with tool for 30 seconds) after this light stays static and u can try uploading that firmware. I think this is somekinda factory recovery state for netgear ?"
This somehow worked for me. It perfectly factory reset the router and I was able to set it up again, didn't even have to upload firmware. Originally I was trying to upload new firmware but my router was so bricked it wasn't even allowing uploads.
After doing the "30-30-30" method I still observed blinking white lights for perhaps 15 seconds, but then it turned a solid orange! From there I set everything up as if it was new, and it works again.
