Ian57
Jan 04, 2022Follower
Blinking white light for MS60
Had 2 full M60 systems. Both routers setup, 1 as an AP. 3 of the 4 sats setup around the house. Yesterday I had to reboot main router and even factory rest it. Today it all crashed, nothing worked. I...
je13air47
Feb 14, 2022Aspirant
This KB worked for me, it was a little annoying, but the tech I had was patient. After we tried all the standards, this was finally the one that got it going.
dmsae
Feb 20, 2022Aspirant
je13air47's method fixed my problem. I had blinking white lights on all satellites after attempting a FW update through the Nighthawk mobile app. I tried power cycling and hard resets, but none of that fixed the problem. I'm not hardware savvy, so I was reluctant to push a FW update through a hardwired connection, but I followed the instructions exactly, and now my my mesh network is working again.
- FURRYe38Feb 21, 2022Guru - Experienced User
It's recommended to use the MR or MS web pages first to push any FW updates to the MS first, then MR lastly using a wired PC. Wireless is not recommended.
TFTP would only be needed as a last resort.
Using the mobile NH app can be problematic and is not recommended to do any FW updates thru.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- StbricehJul 07, 2022AspirantDoing this process fixed your satellites stuck on blinking white problem? Because I have one satellite that's been doing this for months. I gave up on it, I've tried factory reset, pressing the sync and the reset together, it never responds.
- dmsaeJul 07, 2022AspirantYeah, I followed the instructions, and it ended up being easier than I thought
