Ian57
Jan 05, 2022Follower
Blinking white light for MS60
Had 2 full M60 systems. Both routers setup, 1 as an AP. 3 of the 4 sats setup around the house. Yesterday I had to reboot main router and even factory rest it. Today it all crashed, nothing worked. I...
dmsae
Feb 21, 2022Aspirant
je13air47's method fixed my problem. I had blinking white lights on all satellites after attempting a FW update through the Nighthawk mobile app. I tried power cycling and hard resets, but none of that fixed the problem. I'm not hardware savvy, so I was reluctant to push a FW update through a hardwired connection, but I followed the instructions exactly, and now my my mesh network is working again.
Stbriceh
Jul 07, 2022Aspirant
Doing this process fixed your satellites stuck on blinking white problem? Because I have one satellite that's been doing this for months. I gave up on it, I've tried factory reset, pressing the sync and the reset together, it never responds.
- dmsaeJul 07, 2022AspirantYeah, I followed the instructions, and it ended up being easier than I thought
