_JWM_
Jun 06, 2021Follower
Brand new Nighthawk MR60 Vulnerability Detected - update software - already latest
I have a brand new Nighthawk MR60 running firmware version V1.0.6.102_2.0.45, which is the latest. The Nighthawk App on my phone keeps reporting a vulnerability with this device and that I should update the software. It doesn't give me great confidence that the the Netgear App is reporting a vulnerability with the hardware running the most recent firmware. Is this something that I can ignore, or are there some settings that should be changed? Screen capture from the App below.
1 Reply
- Christian_RNETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
