lechatnoir27
Nov 17, 2020Follower
Can I connect another Router to my MR60?
I have the Nighthawk Mesh 6 Wifi Mesh System. HOwever, I am still finding tons of dead spots in my house. I was wondering if you can connect another router through a ethernet port on the Mesh 6? I...
Christian_R
Nov 24, 2020NETGEAR Employee Retired
Hello lechatnoir27,
We recommend that the MR60 is set into access point mode when connecting it to another router.
Christian
- BoltykNov 28, 2020Aspirant
Christian_R why so?
Setting mesh system as an access points going to transform your mesh into three separate access points, right?
- schumakuNov 28, 2020Guru - Experienced User
What's the point of adding a [NAT?] router to a network cable in another part of the location? You would use an access point for such a purpose instead, or e.g. another MR60/MS60 system in AP mode.
Boltyk wrote:Setting mesh system as an access points going to transform your mesh into three separate access points, right?
What is the difference - leaving alone the MR60 does not longer act as a NAT router connecting to the Internet - in your opinion? All the Mesh capabilities (seamless roaming) as well as the wireless backhaul between the MR60 and the MS60 are retained.
- BoltykNov 29, 2020Aspirant
If Mesh system remain Mesh in access point mode - you're right.
You don't want to have a double NAT. So either set second router (mesh one) as AP (so it will be a mesh of access points then?), or first router as a bridge?
btw, what if have mash as a primary NAT, and connect another router as AP to one of the satellites, and this another router has the same wifi name and pass?
And is it a good idea at all if this second router AP is an old one used before the mesh came?
