mcvolution
Sep 10, 2020Follower
Can I replace Fios Quantum Gateway with Nighthawk MK63 mesh router?
I want to replace Fios Quantum Gateway with Nighthawk MK63 mesh router. I do not have fios TV only internet service. Is there any reason I can't replace the Verizon Quantum Gatewat router with the MK63 Nighthawk mesh router? I have a CAT6e cable from the fiber modem in my garage that is connected to the WAN port of the fiso quantum gateway router. Has anyone esle done this? Anything special need to be done?
1 Reply
- Christian_RNETGEAR Employee Retired
Hello mcvolution,
As long as you have a modem or a gateway that can be set to modem mode only you should be fine.
Christian
