Daktyl
May 01, 2021Follower
Can I tell my MR80 satellites what path to connect to the router manually?
I recently purchased the MR80 3-pack as a gift for my friend as he has a weird internet situation. His room isn't very far away from his modem/router, but something in his walls makes it so that wifi...
Christian_R
May 05, 2021NETGEAR Employee Retired
Hi Daktyl,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
