HyperactiveJas's avatar
Jun 28, 2021
Can I use a Nighthawk EAX80 as part of MR60 (mk63s) mesh network
Can I use a Nighthawk EAX80 as satellite as part of my MR60 (mk63s) mesh network?
1 Reply
  • plemans's avatar
    Will it integrate with the system like another satellite? No.
    Could you potentially connect it to the system and have it work? Maybe?
    I say maybe because I've connected extenders to my orbi network before and they worked. they didn't use the backhaul or integrate but they did work.
    But I don't have a MK system (or EAX80) to test it with to confirm 100% if it'll connect and work
    maybe Christian_R knows if it'll function.
    Is there a reason you're wanting to do this instead of just using another satellite?
