yuktaondi
Dec 17, 2023Aspirant
Can MS 60 satellites be used with MR 90 Nighthawk router?
The ethernet port on my MR60 stopped working, so I've upgraded to the MK93. Everything is working fine, but I was wondering if the old equipment could be put to use. I tried pairing the MS 60 satelli...
Areej
Yes, it's possible to repurpose your old MS60 satellites with the new MK93 router for extended coverage. While the app didn't detect additional satellites during pairing, you can manually configure the old satellites to connect to the new router. Ensure they're compatible, check for firmware updates, and adjust settings as needed. This way, you can utilize the strong Wi-Fi signal from the old satellites and extend coverage to desired areas without relying on the wired connection to switches.
