yuktaondi
Dec 17, 2023Aspirant
Can MS 60 satellites be used with MR 90 Nighthawk router?
The ethernet port on my MR60 stopped working, so I've upgraded to the MK93. Everything is working fine, but I was wondering if the old equipment could be put to use. I tried pairing the MS 60 satelli...
michaelkenward
Dec 17, 2023Guru - Experienced User
There seems to be something odd with the Netgear server. That link has stopped working. Maybe it will come back to life soon.
yuktaondi wrote:
Does anyone know if i can get the old satellites to work with the new router for more coverage?
Only in AP mode. So, not the same Mesh.
The table I can't link to shows that MS## devices have limited compatibility with different MR## models.
michaelkenward
Dec 18, 2023Guru - Experienced User
michaelkenward wrote:
Link still bust, but the search engine says:
The MS60 satellite is compatible with the Nighthawk Tri-band Mesh WiFi 6 (MK83) system.·····The following configurations are supported with the MK83:·····MR80 + MS80·MR80 + MS60·MR80 + MS80 + MS60·····For more information:·····Nighthawk Mesh WiFi 6 product page·Nighthawk Tri-band Mesh WiFi 6 product page·What is an Ethernet backhaul ...
No mention of MR90.
