mikey59
Dec 27, 2023Guide
Cannot connect printer to MR70 router!
I have a Brother HL-2280DW that has been working fine for a while & now shows a offline - I've tried everything I can think of to try to get it connected & am having ZERO luck! Trying setting up fro...
Dec 27, 2023Guru - Experienced User
Something to contact Brother about regarding there product.
Trying setting up from scratch, going through (temporary) LAN cable & USB cable, but the printer never shows on network!
I've tried connecting with the WPS PIN & it times out & the printer is withing spitting distance of the router!
Any suggestions?
