mikey59
Dec 27, 2023Guide
Cannot connect printer to MR70 router!
I have a Brother HL-2280DW that has been working fine for a while & now shows a offline - I've tried everything I can think of to try to get it connected & am having ZERO luck! Trying setting up fro...
mikey59
Dec 27, 2023Guide
I've been trying the WPS feature, both the soft push & the PIN but the printer says it cannot find an access point, but it is maybe 6 feet away from the printer!
michaelkenward
Dec 28, 2023Guru - Experienced User
Here are some links to Brother's support pages for connecting printers to wifi.
Set up your Brother machine on a wireless network | Brother
Downloads | MFC-L2700DW | United Kingdom | Brother
Utilities | Downloads | MFC-L2700DW | United Kingdom | Brother
They are model specific, but they should apply to any printer you have.
- mikey59Dec 28, 2023Guide
Will give those a try, thanks.
Dunno how something can work & then all of a sudden not work, with nothing having changed...
