OfirM
Oct 03, 2024Aspirant
Cannot connect to additional MS60 satellite
Hello everyone, I have a NIGHTHAWK MESH SYSTEM MR60 WITH TWO MS60 SATELLITES. The problem is that I have only used one satellite and the other remains in the package. Now after more than 2 years i...
OfirM
It doesn't seem to work. What should i do next? đ
Oct 03, 2024Guru - Experienced User
try hardwiring a pc/laptop into the satellite (shut off the wifi on the pc/laptop). Give it 10 minutes.
Then try connecting to 192.168.100.250 or 192.168.1.250
Should let you log into the satellite.
You could manually update the firmware from there. (download it before you connect the sat to the laptop)
- OfirMOct 03, 2024AspirantI will try and update
- OfirMOct 03, 2024AspirantHi. Any other address to connect directly. I tried both addresses and it cannot log in to the satellite. I have connected the satellite directly to PC with Ethernet cable and disabled wifi
- OfirMOct 04, 2024AspirantHi there,
I still couldn't connect to my additional MS60 satellite. I have tried to do factory reset to the router from the reset button and also erased all settings from web browser but it seems that it doesn't return to its original firmware and it stays with the updated one. Any suggestions?
