IainMurray
Apr 05, 2021Tutor
Cannot Login Using Browser
I have a problem with a New Nighthawk MR60 system where I cannot Login suing the we browser Interface After 3 attempts it asks my Serial Number and Security questions and allows me to rest the Passwo...
- Apr 10, 2021
Curious, you used the default username and password for the login?
Default Setting
Router login User login URL http://www.routerlogin.net
User name (case-sensitive): admin
Login password (case-sensitive): password
Christian_R
Apr 09, 2021NETGEAR Employee Retired
Hello lainMurray,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
