sresam89
Dec 01, 2020Guide
Cannot ping the device in same network (MR60)
Switched to this device 3 days ago and having a hardtime managing my network since then. Worst customer-care support ever even with premium support Spend Three hours on calls all-together today wit...
sresam89
Dec 01, 2020Guide
1. What modem gateway are you connecting it to?
There is an internet modem/gateway my ISP provided, that is where the router is connected to (do you need make and model?)
2. Are the sateliltes hardwired in or running wireless?
Satelites are running wireless
3. the devices you're pinging, what are they?
the static devices are home-automation device, like smart-plugs/sensors/server/rpis...
4. Is it timing out? what response are you getting?
Its just timing out "Destination host unreachable"
5. Have you tried pinging from different machines?
Tried that too, any cannot ping any device that get attached to the satelites from any other device on the router same or different satelite
Dec 01, 2020Guru - Experienced User
Your isp modem/router, is it running in modem/router mode or passthrough mode?
Or is your netgear running in access point mode?
https://kb.netgear.com/30186/What-is-Double-NAT
- sresam89Dec 02, 2020Guide
Its a modem but a passthrough, the wifi-ap device that I use before acts as a bridge on the WAN-side and router function on the LAN
Or is your netgear running in access point mode?Router is not running on AP mode.
I dont think this has anything to do with the Internet
I would expect a basic router to have the minimal routing function to work propertly even when offlineThe router should let other devices connected to it to be discovered/ping, even that seems to be problem at end. Especially when the devices are attacehed to satellites
- plemansDec 02, 2020Guru - Experienced User
sresam89 wrote:Your isp modem/router, is it running in modem/router mode or passthrough mode?
Not sure if i'm getting exactly what you describe here.
What modem/router is it? not all have properly functioning passthrough mode.
This the one I have
https://dzsi.com/product/znid-gpon-2424a/Like I said, if I were to use this product completely in offline mode (without internet)
I would expect this product to have basic routing/switching function with any issues
