sresam89
Dec 01, 2020Guide
Cannot ping the device in same network (MR60)
Switched to this device 3 days ago and having a hardtime managing my network since then. Worst customer-care support ever even with premium support Spend Three hours on calls all-together today wit...
DMGriffin1948
Aug 14, 2021Initiate
I am having the same problem Nighthawk MR60/MS60 MESH network. I am not able to PING or connect to PCs and an HP Officejet PRO 9010 printer over Wi-Fi unless they all happen to use Wi-Fi from the router (MR60). I have one PC that is connected to the router via CAT6 Ethernet that works fine in all cases. It appears, to me, to be an issue with the satellite (MS60). If I power the MS60 off and force everything wireless to use the router's Wi-Fi everything works perfectly. It almost seems that Wi-Fi clients on the satellite are forced to use Wi-Fi separation security. Either that or Netgear has a serious routing issue in their MESH implementation. You are absolutely correct ICMP PINGs do not work either. I have searched high and low for a Wi-Fi separation setting, but no joy. HELP US PLEASE Netgear! Your customers need a fix for this problem.
