sresam89
Dec 01, 2020Guide
Cannot ping the device in same network (MR60)
Switched to this device 3 days ago and having a hardtime managing my network since then. Worst customer-care support ever even with premium support Spend Three hours on calls all-together today wit...
n8man
Sep 28, 2021Star
It's been two months now since Netgear gave me the beta firmware to use (V1.0.6.103_21.03.03_homepod) and there is still no fix for this issue in the offical stable firmware.
I'd be fine with continuing to use this beta firmware but the actual throuthput performance is terrible. Transferring data across the network is excrutiatingly slow. I'm not able to stream plex video to my TV from another computer on the network. What is strange is that access to the internet seems to be uneffected and is full speed.
I'm not sure if the performance issue is a side effect of whatever workaround/fix they implemented to get wifi devices to be able to reliably communicate or if this beta firmware has some kind of special kernel-level debugging enabled (which usually degrades performance). Either way I just can't handle this. I need this fixed or I need to switch to another model and brand of hardware. This system is broken.
Another unforunate thing is that I have this same mesh system installed in two locations (I bought it for my in-laws) and I have exactly the same issues with both systems. It's ridiculous that this gear is still for sale. Netgear needs to fix this.
When I call Netgear they want to charge me because I'm outside of my 90-day purchase window. Screw them.
- n8manOct 05, 2021Star
Here are links to the beta firmware "V1.0.6.103_21.03.03_homepod" (hosted on Netgear's Salesforce instance)
This firmware resolves the issue where some devices could not reach each other on my local network. Now my kids can play their games together and I'm able to use my Apple Homepod devices. The downside is that LAN (but not WAN/internet) throughput seems to be reduced.
MR60-V1.0.6.103_21.03.03_homepod.chk
MS60-V1.0.6.103_21.03.03_homepod.chk
I've had pretty good luck with this firmware but your results may vary. Good luck.
- UpIronsOct 05, 2021Tutor
Thanks for supplying that. I will have to test it out and see how it does for my environment. Nice to know they are at least aware and working on a fix - just wish they'd get it into the next full release quickly.
TBH, I have no idea how long those links will stay up. If they go down then I'll replace with links to my personal google drive.
I just want some transparency about the issue. The official firmware is legitimately broken.
- FURRYe38Oct 05, 2021Guru - Experienced User
Interesting why these didn't get posted to NGs download site:
I don't know why they didn't release these. Definitely don't install these if you don't trust them. I linked them from Netgear's Salesforce account to try to show that they came from Netgear.
