sresam89
Dec 01, 2020Guide
Cannot ping the device in same network (MR60)
Switched to this device 3 days ago and having a hardtime managing my network since then. Worst customer-care support ever even with premium support Spend Three hours on calls all-together today wit...
samuraineet
Nov 14, 2021Aspirant
I had also been getting nagged by an issue where devices connected to the satellite cannot communicate with each other.
But today, I found Netgear released new versions of MR60/MS60 firmware. After installing them to the router and satellite, this issue seems to be away.
https://kb.netgear.com/000064370/MR60-MS60-Firmware-Version-1-1-6-122
I needed to download the firmware from the link above and install it from routerlogin.net > ADVANCED > Administration > Router Update > Manual Update.
Not sure why but the Online Update tab did not work as it was not showing this firmware update was available.
I am using MK62 (MR60 + one MS60.)
- UpIronsNov 14, 2021Tutor
Thanks for the heads up. I am about to go do that update now and will report back after I put it through its paces.
- n8manNov 14, 2021StarI installed the new firmware a few days ago and I been working well for me, maybe even perfectly. I haven’t tested internal network speeds yet.
Yep this is good. They finally fixed it from what I can tell..
I'm averaging a 3ms ping between 2 devices that are on disparate netgear units as well as a 12 MB/s transfer rate which is about as good as expected.
I also ran a few wireshark sessions just to look for anything weird going on and nothing is out of the ordinary, whereas before I was seeing a lot of retransmissions and outright lack of handshaking between devices.
My only wish at this point would be that they would detail what exactly they did to fix it. Doesn't even say anything in the release notes.
- Sanjith92Nov 30, 2021StarI confirm that the Chromecast issue and failure to ping satellite connected devices is now resolved with firmware v1.1.6.122 .
Hope this fix is carried forward to future updates as well .
Release notes say it fixed the airplay issue with iphone/ipad connection to apple tv , so may be same bug was causing issue for Chromecast too .
