sresam89
Dec 01, 2020Guide
Cannot ping the device in same network (MR60)
Switched to this device 3 days ago and having a hardtime managing my network since then. Worst customer-care support ever even with premium support Spend Three hours on calls all-together today wit...
samuraineet
Nov 14, 2021Aspirant
I had also been getting nagged by an issue where devices connected to the satellite cannot communicate with each other.
But today, I found Netgear released new versions of MR60/MS60 firmware. After installing them to the router and satellite, this issue seems to be away.
https://kb.netgear.com/000064370/MR60-MS60-Firmware-Version-1-1-6-122
I needed to download the firmware from the link above and install it from routerlogin.net > ADVANCED > Administration > Router Update > Manual Update.
Not sure why but the Online Update tab did not work as it was not showing this firmware update was available.
I am using MK62 (MR60 + one MS60.)
n8man
Nov 14, 2021Star
I installed the new firmware a few days ago and I been working well for me, maybe even perfectly. I haven’t tested internal network speeds yet.
