sresam89
Dec 01, 2020Guide
Cannot ping the device in same network (MR60)
Switched to this device 3 days ago and having a hardtime managing my network since then. Worst customer-care support ever even with premium support Spend Three hours on calls all-together today wit...
ktiedt
Jan 08, 2022Aspirant
"Id make a new post or contact NG support if you seem to have continued problem with this. "
The original problem was never fixed either... so fragmenting the knowledge base makes little sense there... I also just spent over 3hrs on the phone with support regarding this issue and had almost the identical problem as every other customer here... incompetent "support experts".
I have the latest firmware, it does not change the issue at all, and like the earlier posters, "check for updates" does not work on my MR80/MS80 devics they each had to be manually updated, which when you goto the support page for the device, only gives you the router version... you have to go through the release notes page to find the download for the satellites... Seriously how can one company screw up one thing in so many different ways.
Jan 09, 2022Guru - Experienced User
You can try more updated FW and see:
- ktiedtJan 16, 2022Aspirant
Already tried the latest firmware... If firmware was the problem... this would have been fixed over a year ago when the problem was identified.
- FURRYe38Jan 17, 2022Guru - Experienced User
Have you contacted NG support to let them know what your seeing?
- ktiedtJan 18, 2022Aspirant
"I also just spent over 3hrs on the phone with support regarding this issue and had almost the identical problem as every other customer here... incompetent "support experts"."
That number is now over 6hrs... somehow I've managed to need to escalate my ticket to "level 2" twice now... and still somehow never talked to level 2 support...
Its cool you want to help but... you're literally just making folks repeat the same things they've already repreated both in their details here, and in their calls to support.
