JerryHas
Mar 03, 2021Aspirant
Cannot see extender
Hi all I have just purchased a Nighthawk X4S AC2200 Model 7500. I have set it up, connected it to my router wirelessly and have 5 blue lights showing. The problem is none of my devices are showin...
Mar 03, 2021Guru - Experienced User
What router are you connecting it to?
What firmware is on the extender?
Did you set it up using wps or the installation assistant?
Are you using the "one wifi" feature? Its the mesh mode that uses the same ssid as the router.
- JerryHasMar 03, 2021Aspirant
Sorry not very good at this tecno stuff!
Connecting to a SKY Q router
Firmware, ??? Lost me
Used WPS
Ha Ha.......not a clue. Sorry.
Thank you.
- plemansMar 03, 2021Guru - Experienced User
What actual skyq router is it?
If you used wps to setup the extender, its default setup uses the mesh function. that's where the ssid for the extender is the same as the ssid for the router. In that mode, the device itself (phone, tablet, etc) is what roams between the router/extender.
Some devices you can change the roaming aggressiveness. You can try manipulating this a bit.
How to change WiFi Roaming Aggressiveness or Sensitivity in Windows 10 (thewindowsclub.com)
- schumakuMar 03, 2021Guru - Experienced User
JerryHas you are doing good - convinced with he help from some communit members you can figure out! Some alternate proposals or tests here:
Check the Sky router for the presence of the extender in the connected devices and/or DHCP table for the IP address assigned by the router. Now you should be able to access the extender using a Web browser using just the IP address, and login there.
Alternet approach would be to factory reset the exender, and reinstall from scratch using the Netgear Installation Assistant as shown in complete manual on p.13.
Here the reference to the documentation -> Nighthawk X4S AC2200 Tri-Band WiFi Range Extender User Manual
Hi again
I really appreciate your help......... but, I factory reset the extender, The one blue light flashed for a while then went solid as it should according to the book. The problem starts here, the book then says "open the wifi connection manager on your device and connect to NETGEAR_EXT, fine except it isnt there, still just the SKYD499D which means I have no way to connect. Wierd, but I appreciate your efforts, thank you.
