JerryHas
Mar 03, 2021Aspirant
Cannot see extender
Hi all I have just purchased a Nighthawk X4S AC2200 Model 7500. I have set it up, connected it to my router wirelessly and have 5 blue lights showing. The problem is none of my devices are showin...
JerryHas
Sorry not very good at this tecno stuff!
Connecting to a SKY Q router
Firmware, ??? Lost me
Used WPS
Ha Ha.......not a clue. Sorry.
Thank you.
Mar 03, 2021Guru - Experienced User
What actual skyq router is it?
If you used wps to setup the extender, its default setup uses the mesh function. that's where the ssid for the extender is the same as the ssid for the router. In that mode, the device itself (phone, tablet, etc) is what roams between the router/extender.
Some devices you can change the roaming aggressiveness. You can try manipulating this a bit.
How to change WiFi Roaming Aggressiveness or Sensitivity in Windows 10 (thewindowsclub.com)
