dalemwebb
Mar 15, 2023Aspirant
Can't access router via 192.168.1.1
Xyxel C3000Z (CenturyLink) modem bridged to Nighthawk MR60 Mesh Router with one satellite. Windows 11. Microsoft Edge. Something really screwed up my router settings. Had to do a factory reset. ...
Mar 16, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
Try Option#2 first.
If the modem uses 192.168.1.1 then the MR maybe using a 10.0.0.1 address for it's web page.
Be sure to clear out all browser caches and remove any saved PW profiles from the browser as well.
Use a different browser, MS-Edge, Firefox, Opera or Safari
