dalemwebb
Mar 16, 2023Aspirant
Can't access router via 192.168.1.1
Xyxel C3000Z (CenturyLink) modem bridged to Nighthawk MR60 Mesh Router with one satellite. Windows 11. Microsoft Edge. Something really screwed up my router settings. Had to do a factory reset. ...
michaelkenward
Mar 17, 2023Guru - Experienced User
dalemwebb wrote:
I don't remember exactly WHAT I did when I first set up the MR60. I followed a set of instructions that I found on-lime. I believe the modem is bridged; I can't get to the C3000Z from my computer/browser.
That's one of the issue with "bridged" devices. They may not have an IP address that you can reach from the router. The instructions for setting up the C3000Z might have some clues.
Windows says, "the default gateway is 192.168.1.1." Windows was able to get to the router via routerlogin.net; it was there I entered the PPoP information. Tried routerlogin.net again and was able to reach router.
Maybe that's a clue about the state of the modem. Could be that the MR60 isn't the default gateway.
If you can get into the MR60 you should be able to see an "Attached Devices" section with the IP address of the stuff connected to the MR60. It will also show the router's IP address.
dalemwebb
Mar 17, 2023Aspirant
Sorry. I can't see the routers IP address on the Attached Devices page. It shows the satellite (192.168.1.29), but don't see the router IP anywhere.
As long as I can reach the setup page using "routerlogin.net," I guess I'm OK.
Thanks for your help.
- FURRYe38Mar 17, 2023Guru - Experienced User
Routers IP address will be on the Advanced Tab. Won't be on the Attached Devices page.
