oghagen
Feb 13, 2022Aspirant
Cant connect Sonos Roam with MR60
Hi! I have my Sonos system connected to my Nighthawk MR60 network (1 router, 2 satellites). My Beam, One and three Symfonisk connects with no problems. BUT my Sonos Roam wont show up. When i turn th...
- Feb 14, 2022Solved!
MU-MIMO was disabled, when I enabled it the Roam appeared as it should!
Razor512
Feb 13, 2022Prodigy
If you go to the MR60 web UI, and then go to the Advaced > Advanced Setup> Wireless Settings, do you have an option to enablee or disable fast roaming?
If available, try testing with it enabled and disabled. This will help troubleshot if the Sonos device is having issues with 802.11r type functions or not.
- oghagenFeb 14, 2022AspirantSolved!
MU-MIMO was disabled, when I enabled it the Roam appeared as it should!- FURRYe38Feb 15, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
