dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
Christian_R
May 20, 2020NETGEAR Employee Retired
Hello dbarbee,
We have not received reports of the Nighthawk Mesh system not being compatible with a switch. Have you had a chance to try a different switch?
Christian
dbarbee
May 20, 2020Initiate
Hi Christian,
It was definately the router no working with the switch. I moved th cable from the router from the TrendNet switch to my Powerliner Adapter's (WD Livewire) built in 4 port hub/switch and it started to work. I'm not sure if the Livewire's switch/hub is gigabit speed. The powerline transmission rate is only 200Mbs
Duncan
- Christian_RMay 21, 2020NETGEAR Employee Retired
Hi Duncan,
Thanks for getting back. I'll forward this post to our product teams for further input. In the meantime, I can assist with support getting in contact with you for further investigation. If you wish to be contacted, please send me a private message with your contact info.Christian
- Christian_RMay 27, 2020NETGEAR Employee Retired
Hi Duncan,
Thanks for the info. I have forwarded it to support and they should be contacting you as soon as possible.
Christian
