dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
dbarbee
May 20, 2020Initiate
Hi Christian,
It was definately the router no working with the switch. I moved th cable from the router from the TrendNet switch to my Powerliner Adapter's (WD Livewire) built in 4 port hub/switch and it started to work. I'm not sure if the Livewire's switch/hub is gigabit speed. The powerline transmission rate is only 200Mbs
Duncan
Christian_R
May 21, 2020NETGEAR Employee Retired
Hi Duncan,
Thanks for getting back. I'll forward this post to our product teams for further input. In the meantime, I can assist with support getting in contact with you for further investigation. If you wish to be contacted, please send me a private message with your contact info.
Christian
