dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
ktwel
Jun 20, 2020Aspirant
I have the same problem -- nothing plugged into that port is recognized.
schumaku
Jun 21, 2020Guru - Experienced User
ktwel wrote:I have the same problem
Not the same - the OP had a TrendNet 8-Port gigabit switch TEG-S82g that did not wanted to sync, and a WD Livewire PLA that works.
ktwel wrote:nothing plugged into that port is recognized.
Define nothing (make, model) please.
Used a known 100% working direct patch cable or some in-house wiring? Tried a crossed-out cable type - because not all Ethernet interfaces support Auto-MDIX (automatic medium-dependent interface crossover) which become standard with Gigabit?
