dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
tonerrg
Jul 06, 2020Aspirant
I'm having a similar problem. MR60 with 1 satellite and SB6121 modem do not recognize that they are connected using known good patch cables. If I connect a device directly to the modem it is recognized and works properly.
This system is only 4 days old and was working fine until sometime while we were sleeping last night.
Christian_R
Jul 09, 2020NETGEAR Employee Retired
Hello tonerrg,
If you recently purchased the device, I would recommend contacting our support team as your device is provided with 90 days of complimentary support. You can contact support by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Christian
