dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
DaveNeely
Aug 26, 2020Guide
Same issue here. New installation, router connected to a switch which also has two downline switches attached. Worked great for a few days then just stopped working. None of the computers on the LAN can get IP addresses, Wifi still working. Was there a new firmware update or something? so weird for it to stop working right in mid day with no actions on my part.
DaveNeely
Aug 27, 2020Guide
My issue was unrelated to firmware update, I had a bad switch downstream that was messing everything up. Just FYI, the one causing the problem was a TP Link 5 port switch I got from Home Depot.
