dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
Omuamua
Oct 08, 2020Initiate
I hope my troubleshooting procedure may help others. My configuration is below
Xfi Modem(comcast) >>> MR60 Router >>> TP-Link TL-SG108 Unmanaged 8-port switch
Problem: Unable access internet from the TP-Link switch.
Solution:
1. Establish direct LAN connection from your MR60 to PC and ping MR60's ip address.
a. Success: Your router and the cable is good.
b: Failed: Try using different network cable.
2. Establish LAN connection to your pc from the switch and see if you can ping MR60's IP address.
a. Success: Your switch is probably working fine. Check other ports on the switch.
b. Failed: Follow these steps in order
i. Disconnect all the network cables on the switch including power.
ii. Reboot Modem first then Router(Wait until both established successful connection)
iii. Connect Power cable to the switch.(Wait for 1 min)
iv. Connect LAN cable from your MR60 router (Wait for 2 min)
v. Now connect the network cable from switch(port 2) to your PC and ping
MR60's ip address. This should resolve the issue. Then connect rest of the network cables to the switch.
I hope this helps!
