dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
claycat1
Oct 28, 2020Aspirant
Has anyone found a resolution for this issue?
I'm experiencing the exact same symptoms whereby my unmanaged switch does not see that either the router or a satelite of the MR60/MS60 are plugged in.
- BigShotJan 29, 2021Aspirant
I have several ethernet-wired devices connected to the Netgear GS308P switch (devices like printers, NAS, etc.). I'd like to expose those to the mesh network by connecting the switch to the ethernet port on the MR60, but it doesn't seem to be working. Is what I trying even possible?
claycat1 wrote:Has anyone found a resolution for this issue?
- claycat1Jan 29, 2021Aspirant
BigShot , i never could get my switch to recognize that the MR60 (router or satellite) was plugged in and the Netgear support team was of no help. I returned the equipment and opted for another, non-netgear mesh system. In addition to this issue, I found the speeds provided from the MR60 were very poor at small distances from the router/satellite.
