dbarbee
May 16, 2020Initiate
Can't connect the ethernet port on an MR60 to a switch, it doesn't seem to recognize the switch.
I replaced my very old internet gateway with a new MR60 mesh system with 2 sattelites (MS60). I'm not sure what rhe exact model number is as the Model selector for the formum post does not recognize ...
punu
Jul 20, 2021Aspirant
The ports started working after I disabled Netgear Armor from Nighthawk app - Settings - Security
punu
Sorry My bad.. disabling the Armor enabled ethernet port on a TPlink extender.. still the ports on the NETGEAR unmanaged switch are not working. Will try to contact support team tomorrow.
Setup - ISP modem - Netgear Switch - MK63 router - Satelites + Extender + VOIP on router ethernet
Connected TV and laptop on Switch ports .. Internet NOT working
- punuJul 21, 2021Aspirant
Finally the issue got resolved.
ISP modem was actually a router combo with LAN ports
Looks like IP conflicts with switch and MK63 router
To solve.. changed the IP range of Nethear MK63 router using the routerlogin.com to a new range like 192.168.192.1 (Advanced -> setup -> LAN setup)
Boom other ports connected to switch started working.
