matt7thom's avatar
matt7thom
Follower
May 31, 2021
Can't connect with Netgear app because network name was previously changed (nighthawk mesh wifi 6)
My mesh router was setup previously and I changed the network name and password from the defaults. Now after moving, and setting up a new network, with a new mobile device, the Netgear app insists I connect to NETGEAR14, but it's not available, I only have the network name I previously used.
I think I should do a factory reset with a paperclip. Is that the solution?
  • Hell matt7thom,
    Correct! I would suggest performing a factory reset and running through the setup assistant again.
    Christian
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hell matt7thom,
    Christian
