fredboer
Feb 06, 2022Star
Can't maintain connection with Epson 3830 - and issues with HP wireless printers.
Background: My new Nighthawk MK62 AS1800 Mesh router and satellite are providing great coverage and high speeds. Setup was a breeze. BUT... I cannot maintain a wireless connection to my (also new) E...
- Feb 06, 2022
Oh, wait... you suggested the satellite. Sorry not to read more carefully. I have only one satellite. It is positioned on the main floor, and uses an ethernet cable as a backhaul. If I bought a *third* satellite, and used it wirelessly, I suppose I could then use the etherenet connection to the printer. Would that work? Still. I don't feel like spending even more money - since for everything but the printer, the wifi is great.
Thanks for the suggestion!
Fred
Feb 06, 2022Guru - Experienced User
From looking at it, the ET-3830 has an ethernet port. Why not wire it into one of the satellites?
fredboer
Feb 06, 2022Star
plemans wrote:From looking at it, the ET-3830 has an ethernet port. Why not wire it into one of the satellites?
Yes, thank you. That does work. However I want to place the printer in an upstairs bedroom. There is no ethernet connection, and I don't want to have to run a cable up two floors from the basement. You are correct in suggesting this - currently I have put the printer in the basement and have hard-wired it to the network. That works, but I was hoping that a brand new router and a brand new printer would be able to communicate wirelessly.
