fredboer
Feb 06, 2022Star
Can't maintain connection with Epson 3830 - and issues with HP wireless printers.
Background: My new Nighthawk MK62 AS1800 Mesh router and satellite are providing great coverage and high speeds. Setup was a breeze. BUT... I cannot maintain a wireless connection to my (also new) E...
- Feb 06, 2022
Oh, wait... you suggested the satellite. Sorry not to read more carefully. I have only one satellite. It is positioned on the main floor, and uses an ethernet cable as a backhaul. If I bought a *third* satellite, and used it wirelessly, I suppose I could then use the etherenet connection to the printer. Would that work? Still. I don't feel like spending even more money - since for everything but the printer, the wifi is great.
Thanks for the suggestion!
Fred
fredboer
Feb 06, 2022Star
I guess not everyone has problems - which is a bit of a mystery to me. I did have a connection once that was maintained for 7 or 8 hours, but then dropped. But I've tried everything, and usually it drops after 15 minutes or so. The printer is close to the router (I don't think I mentioned that) so signal strength isn't an issue.
But I did wonder - anyone think that Netgear might ever enable the ability to manipulate separate 2.4 and 6 Ghz bands with the MK60 through a firmware update? That would be great. I wonder if something like that could be done with a firmware update, however...
Thanks for listening and responding!
Fred
Feb 06, 2022Guru - Experienced User
the only system that can seperate out the 2 is the MR80 series.
Did you try using a reserved ip address for the printer? not the static route
