fredboer
Feb 06, 2022Star
Can't maintain connection with Epson 3830 - and issues with HP wireless printers.
Background: My new Nighthawk MK62 AS1800 Mesh router and satellite are providing great coverage and high speeds. Setup was a breeze. BUT... I cannot maintain a wireless connection to my (also new) E...
- Feb 06, 2022
Oh, wait... you suggested the satellite. Sorry not to read more carefully. I have only one satellite. It is positioned on the main floor, and uses an ethernet cable as a backhaul. If I bought a *third* satellite, and used it wirelessly, I suppose I could then use the etherenet connection to the printer. Would that work? Still. I don't feel like spending even more money - since for everything but the printer, the wifi is great.
Thanks for the suggestion!
Fred
PaoloPe
Feb 07, 2022Guide
Hi,
try to reach, using web interface, Advaced (Tab) -> Advanced Setup -> Wireless Settings
Try to disable:
"Enable AX"
"Enable MU-MIMO"
"Enable Implicit..."
Verify if one of this parameters conflicts with your wireless printer.
Paolo P. - ITA
