fredboer
Feb 06, 2022Star
Can't maintain connection with Epson 3830 - and issues with HP wireless printers.
Background: My new Nighthawk MK62 AS1800 Mesh router and satellite are providing great coverage and high speeds. Setup was a breeze. BUT... I cannot maintain a wireless connection to my (also new) E...
- Feb 06, 2022
Oh, wait... you suggested the satellite. Sorry not to read more carefully. I have only one satellite. It is positioned on the main floor, and uses an ethernet cable as a backhaul. If I bought a *third* satellite, and used it wirelessly, I suppose I could then use the etherenet connection to the printer. Would that work? Still. I don't feel like spending even more money - since for everything but the printer, the wifi is great.
Thanks for the suggestion!
Fred
PaoloPe
Feb 07, 2022Guide
Hi,
try to reach, using web interface, Advaced (Tab) -> Advanced Setup -> Wireless Settings
Try to disable:
"Enable AX"
"Enable MU-MIMO"
"Enable Implicit..."
Verify if one of this parameters conflicts with your wireless printer.
Paolo P. - ITA
fredboer
Feb 10, 2022Star
P.S. Just thought I should post that I had cause to talk to tech support about another question, and the technician and I got talking about the printer disconnecting. He suggested that I disable broadcasting the SSID. I didn't save the conversation but by disabling broadcasting (under the 5 GHZ settings) this would resolve the issue. He also suggested setting a "Short Preamble". I was dubious, but it seems to have worked. I've gone a couple of days without a disconnection.
Thought I'd post that here in case it might help someone else.
I appreciate the help and suggestions that were provided here!
Fred :)
- FURRYe38Feb 11, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
