mengnighthawk
Mar 03, 2022Aspirant
cant play or connect to call of duty servers using nighthawk m5 and mk63 mesh system
. hello i just upgraded my previous Nighthawk m1 with tp link ac1750 router to my new nighthawk m5 connected to my new nighthawk mk63 mesh system. everything works fine but i can't play call of du...
- Mar 10, 2022
Dang....
You mgiht set a static IP address on the MRs web page under Advanced tab/Internet. Change from DHCP to Static, input that IP address, Subnet mask would be 255.255.255.0 I believe, Gateway would be the M5 IP address seen on it's LAN side so maybe thats 192.168.1.1 or could 192.168.0.1. DNS you can use the M5s IP address on the LAN or use a custome DNS addresses.
Or easiest would be to configure the MR for AP Mode then and use the M5 as your host router with its limited router features.
Mar 03, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with Nighthawk MESH (WiFi6 MK Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
