bryansdiego
Aug 24, 2023Aspirant
Can't Turn Remote Management Off - MR60 Mesh Router
If anyone can help I appreciate it. I have the latest firmware. I am just trying to turn off the Remove Management. When I unselect and then hit Apply it does not save the setting, and turns it...
- Aug 25, 2023
Ok, lets try a Factory reset and setup from scratch.
jhonibhram
If you find yourself unable to disable remote management on your MR60 Mesh Router, you can try the following steps:
- Open a web browser and enter the router's IP address to access its settings.
- Log in using your credentials.
- Within the settings interface, locate the section related to remote management.
- Make sure to select the option for turning off or disabling remote management.
- If you encounter persistent issues, it might be helpful to check for any available firmware updates that could resolve the problem.
- Alternatively, seeking assistance from Netgear's support team could provide further guidance in addressing the remote management concern on your MR60 Mesh Router.
