bryansdiego
Aug 24, 2023Aspirant
Can't Turn Remote Management Off - MR60 Mesh Router
If anyone can help I appreciate it. I have the latest firmware. I am just trying to turn off the Remove Management. When I unselect and then hit Apply it does not save the setting, and turns it...
- Aug 25, 2023
Ok, lets try a Factory reset and setup from scratch.
michaelkenward
Aug 25, 2023Guru - Experienced User
You already have the latest firmware, but there have been rare cases where reinstalling the firmware can mend minor errors in it.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You could also see if a reset "unsticks" the controls.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
bryansdiego
Aug 25, 2023Aspirant
Wow, thank you so much!!! I will try and first manually redo the firmware, and then if that doesn't allow me to turn off remote management, do a factory reset, correct?
